| Hi, (By the way I have a friend who lives in Aurora....) so what have you done to the car recently? Have you checked for boost leak? (vac test) Have you checked for error codes? Have you cleaned and checked all the connectors? When was the last time you did a full service, air, fuel & oil filters, oils and plugs? from you description, it sounds like a vac leak, check all the vac lines first. If you can't find a leak do a vac/pressure test on the induction system. cheap way.. [ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.89 ] if there is a leak it will depend on how standard your car is see here for areas that are relevant. [ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.88 ]
